Front end noise, further insights requested
Laz
Tomorrow I'll be having the anti-sway bar bolts retorqued. What I've noticed is the noise seems to occur when the car (2001 base Boxster, no mods) is fully warmed up. Ambient temperature doesn't seem to be a factor.
Example: Took a 50 mile drive and parked on a grassy field. Lots of plonking from up front. Left a few hours later, air temperature still about the same, but the front end was quiet.
Based on this, are there any other possibilities? (I also suspect the larger, central underbody panel, as I've damped/removed most everything else to no avail: Hood, panels inside trunk, battery and side panels, panel under passsenger dashboard.)
Someone at PPBB suggested checking the radiators, too.
Thanks.
Edited by Laz
Thanks.
Update: Complete changeout of drop links didn't help.
Thanks.
LAZ, did you get anywhere with this? its driving me f%^*ng mental and has cost me a fortune!!!! :cursing: , have replaced front drop links, RHS suspension arm and engine mount. Same thing, only when car is hot. :censored:
