instrument clock/oil level indicator missing?
  • 8 months later...
Hi
This has just happened to me (ie the clock, odometer, oil level displays etc keep going off) if i push on the binnacle they come back on for a brief moment.
Looking at it it looks more like lcd or led technology as opposed to a simple bulb
Did you get your fixed if so how ?
Cheers
Karl.
Hi
Cheers
Karl.
the bulb lights up the LED stuff; without the bulb, the LED can't be seen. probably when you're pushing on it, your jiggling the bulb and the filament is temporarily making contact and lighting the bulb. it could also be a poor contact between the bulb housing and the circuit board. it's cake to check / replace.
