Headliner removal to repair rattles?
I have an '02 Carrera.
I did a search and did not come across any particular information on how to remove the headliner.
I constatly hear rattles and I want to fix this.
I could probably figure it out, but usually this means taking a very long time and usually messing something up in the process.
Any suggestions? Loren?
  • 2 months later...
Loren,
I would also know the best way to remove the rear part of the headliner (996 C4S) so I could insert some sound dampening material. I have a custom installed audio system, but the area under the headliner rattles when the bass gets loud.
Jeff
  • 2 months later...
Loren....I would also like to know the instructions on how to remove the headliner from a 2002 C2....mine recently developed a rattle as well.
I figure I'll be able to take apart the entire car soon.......
  • 4 weeks later...
I should be sleeping right now, but I'm obsessing about my rattling top.
My car is '02 C2 Coupe. Is it the sunroof? The braces that hold the roof in place? The ghost of Christmas past? Why, why, why must these cars be so perfect, yet so VERY flawed......????!!!!
Loren...any DIY that will keep me out of a straight jacket?
Chris
Chris
You need to figure out if the noise is in the sunroof or headliner or even the A,B , or C pillars.
There are 4 TSBs on noises in the sunroof. I suggest you start by reading the TSBs and seeing if any of them describe your problem.
12a/98 6014 New Sunroof Drive Motor
5/01 6028 Noises from the New Style Sunroof Frame
1/03 6028 Tilting/Sliding Roof Noises
12/98 6040 Work on the Sliding Roof
