Note: I have searched past threads.
On a 2001 996C2, ordered the Becker Aux cable, just not sure where the best place to run the miniplug cable is. I was thinking in the footwell of the passenger side, like over the carpet on the center console ?
Any suggestions? Is that piece of carpet removable? (does anyone have pictures)? I will NOT be running power, just a simple miniplug aux in... I want to keep the car as stock as possible.
Many Thanks, Ross
You could run the cable down the center console and out through the ash tray. See my DIY for details.
Or you could drill a hole in one of the front console storage bins and drop the mini phone plug down through there. That way you can store the ipod in the bin.
The bins are held in with tabs and pull right out.
That may be the easiest... a little hole in a replacable bin would be hardly noticeable...and it is real easy to do ...
