Bleeding brakes with PSM
The tech manual desribes a two part process, first bleed as normal then use a System 2 tester to bleed the brakes. I'm confused, does anyone actually do ths or can I just bleed as normal with a power bleeder. I'm want to put on some new pads(Pagids) before the next track day.
