OEM Short Shifter Install Help
Does anybody have really DETAILED installation instructions for a Porsche OEM short shifter? I have read other posts that say it is easy but I'm extremely mechanically challenged.
I can be a real spaz at times when it comes to mechanical things, particularly in my Boxster where I care how it works and looks. When I installed the Porsche OEM 997 shifter with housing in my 986, I only used the B&M instructions. (Well, I did spend some time with Tool Pants, who gave me a few pointers, only a few which I remembered). The B&M instructions gave me enough details. The biggest problem I had was getting the rear center console out without buggering it up. The trick is to slide the passenger seat forward, then tilt the seat way back.
In hindsight, I would have also bought the DVD (look under the Online Docs Menu) for 9x6 Werks DVD (same comment applies to the Litronic installation). If you have a 986 (don't think so, based on your screen name), you might also want to get the Bentley service book.
