Telephone wiring
The easiest place in the phone prep plug in the center console - but I'm not sure that UK cars get that as standard. Do a search here for "phone prep".
If you don't have the connector then post again and I'll have a look at the schematics.
Crickey that looks the business, I'll go and have a look....
(some time later...)
i dont seem to have it
how do I get powered up?
also how do I get the radio out?
How to remove the radio
If you go to the central locking/alarm control under the left seat the Black/Brown wire (connector 1 pin 36) should be switched +12 volts . The Red/Green wire (connector 2 pin 7) should be unswitched +12 volts and the Brown wire (connector 2 pin 1) should be ground.
Thanks, if I get the radio out can I route the telephone output through the speakers, add mute, get power, add ipod input... via the socket at the back of the unit?
Is there a desciption of the pin layout pls?
also there are many references to other articles in the forum eg. "How to remove the radio", are these listed somewhere
Mark
