Hello there. I've had my 1999 c2 coupe now for a few weeks and I've noticed that if I'm running errands or doing a lot of stop and go traffic, and then go to restart the car when the engine is still warm, sometimes it cranks a bit slow. I usually end up turning the key back to off and then turning it to the on position and holding it there until the car starts. It doesn't really take a long time to start, but definately longer than normal, which is why I notice it. This has happened a few times. The battery is showing a full charge. Is this normal? If not, what are the possible causes? thanks, Scott.
How old is the battery?
The sticker on the battery says 2005. But I am in Arizona and the prior owner indicated that the car had not been driven for a couple of months before he began driving it again just before I bought it.
Thanks for the advice. I will check the battery levels. Forgot to mention that the ignition switch was replaced 6 mos. ago, so that is probably not the problem.
