Front seat belt removal on a TT Cab
Removing seat belt and fitting
1. Press out the covering cap 1 with a screwdriver. Unscrew fastening screw 2 . Remove the seat belt with fitting 4 and spacer sleeve 5. Removing side−panel lining.
2. Removing deflector. Unscrew fastening screws 6 from the deflector 7.
Removing belt tensioner. (Only on vehicles with belt tensioner).
3. Removing automatic belt device. Unscrew fastening screw 8 from the automatic belt device 9.
Installation is reverse of above.
Makes sure the belt moves freely before tightening down.
Torques:
Seat belt and automatic belt device - 50 Nm (37 ftlb.)
Deflector - 10 Nm (7.5 ftlb.)
Pretty much the same as the Carrera Cab.
1. Pull seat belt rose cover (4) up and off.
2. Undo fastening screw (6) behind it (be careful not to drop it into the chassis).
3. Detach side-panel lining by unscrewing the hex bolt (2) for the rear seat latch. Pull locking lugs of side-panel lining out of the clips in the rear side section and move forward enough to get at the back of the speaker.
4. Disconnect the loudspeaker electrical plug connection and disconnect. Remove panel.
