P/N needed for 993Euro RS Motor Mount
RayGT3
Apparently the current hot set up for replacing the sloppy "comfort" GT3 motor mounts, is to use the 993 Euro RS mount. I would appreciate the OE P/N as well as any pics/drawings that might be available. Your response to this is appreciated.
Tnx
Ray
964.375.043.81 Engine mount RoW 993 RS (2 required) -- MSRP $151.51 (each) - as of May 2006)
Do you need the bolts and washers too?
Need bolts and washers, Mr Rieser mentioned the bolt needs to be longer than OE though, 130mm.
