Oil leak
Just took my 02 Tip to have what I thought was an RMS leak fixed. Mechanic says that the leak is coming from where the 2 engine half's are sealed together. Is this possible? He is advising a complete teardown of the engine to "re-seal" the engine at 50-60 hours of labor!!!! Makes no sense to me..............
I would say this is highly unlikely although possible. Get a second opinion or look for yourself if you're a hands on kind of guy. If this is in fact a leak between the case halves you may have defective cases with out of spec machined surfaces, porosity, or some other issue, any of which would be considered a manufacturing defect. Contact Porsche and try to get them to Goodwill the repair if your car is out of warrenty.
