Cabriolet top problem
I have a 1999 996 Cabriolet. While cleaning the interior I got the brilliant idea to open the top half way so as to clean and protect the rubber parts. The top was in this position for about an hour. Upon finishing the job I went to fully close the top and the nothing happened. Brake was on and both engine and trunk lids were closed.
After following the procedure in the manual I closed the top but have since been unable to to operate the top automatically.
Prior to my "detail work" the top operated perfectly. Any suggestions and what to do before taking it to the dealer.
Thanks.
William
William,
do a search by "convertible", there are a few checks that are simple like fuses, etc. Also, the handbrake ligth on when the brake is pulled? There is a small swith there that can get rusty and not make contact. Finally, the DIY has instructions for adding hydraulic fluid. Common issue, also for a 99 (like mine).
As above, make certain the emergency brake light logo on the dash is illuminated when the brake lever is pulled. If not disassemble the center rear console and either unstick or replace the switch. The top not operate unless the brake switch is activated as verified by the dash light.
  • 2 months later...
I just had this gremlin pop up yesterday. My car is a 2002 C4 Cab. I just recently had the X74 suspension put in, but hopefully this is not related to that modification. I have had no problems, nor any hint of problems until yesterday. It was raining and my car was in the garage with the top stowed. I get into the car to go to work and hit the top close button. Nada. I did a quick check of the fuse and that was fine. Having to get to work, I took my other car.
When I got home and had a little more time to take a look at things and do a little bit of web research on the topic, this is what I found. The button actuates the rear top cover and the latch, but that's all. The top itself does not raise or lower. The side flaps don't kick into action because the top doesn't stow. And the windows don't do their thing either when the buttons are pressed. Only the latch and the rear cover do their little dances when the open and close buttons are pressed.
I did all the quickie checks. Fuse is OK. Parking brake is OK with Park Light illuminated on the dash. Does the exact same thing using the key from the outside. I'm able to move the top after disengaging the hydraulic drive with the allen wrench behind the rear passenger seat so at least I'm able to drive it now.
I'm going to take the thing apart this weekend and check the hydraulic fluid reservoir, since that seems to be the next more common thing to check after the parking brake sensor. I hope that is all that it is, but I'm skeptical.
Also in the process of manually lifting the top, I wrenched on the the driver side rear flap and ended up having to take that out, R&R it, and put it back in. I wonder if I further screwed things up with that maneuver as I understand that there are some sensors attached to that piece. But IF those sensors are not working, would that prevent the top from going up and down? I do hear the normal click, click, clicks that are mentioned in other posts and the dash light does blink indicating some fault.
Has anyone else had this combination of faults in the top mechanism? If not, sounds like another $trip$ to the dealer.
David
The only thing I can think of is the fluid or the main motor for the pump being out.
Where you able to close it?
To get to the rear shocks and remove them, the mechanic has to put the top on the midway postion, and remove the rear carpet cover from the convertable stowage area. All the convertible components are exposed and yes, could have something to do with the work or potential of someone inadvertly leaning ro pushing the wrong thing.
From my own observations, when I did my suspension work, I had to be careful on what to lean on or push when removing the nuts from the bolt tower.
Hi All
Below is some of what the shop manual has to say on the convertible top function. The actual trouble shooting is quite specialized because special tools are required. It sounds like you may have a faulty micro-switch
I am having a problem with my top also, it is in the convertible top fully open (or down) position. When I actuate the top switch I get the click clack sound from the control module but no action. Recently I topped up the hyd fluid (as per Izzy's DIY)to correct an intermitant cab top function and the top worked perfect.
I have two questions for those who have moved the top by manual method;
If I put the top up by the emergency (manual) method, will the top need to be calibrated?
Does anyone know if the durametric code reading software can read and clear top function codes?
This is alittle long and no diagrams
911 Carrera (996) Convertible-top diagnosis
General information
Diagnosis
The monitoring of signals by the convertibletop
control module enables the system to
perform reliable, precise diagnosis. Further,
certain additional functions, such as e.g.
test of drive links and of input signals
can be activated using the Porsche
System Tester 2 and their
function checked.
General infonnation
Convertible-top control
Each single step of the opening/closing process
is only executed on condition that the preceding
step was performed correctly.
If a single step is not confirmed within a
given time, the actuation of the drive
motor is interrupted. The fault memory can be read out and
erased with the Porsche System
Tester 2. The diagnostic socket is
located below the knee guard
on the driver's side.
At the beginning of a process, the limit switch
or potentiometer values have a particular
configuration, which is examined
by the control module.
The control module monitors itself and
the connected components. The results
are read out via the diagnostic interface.
625_96
61 01 Diagnosis/troubleshooting, convertible top
Printed in Germany -II, 1998 99661Dl
61-D3Convertible-top diagnosis 911 Carrera (996)
Overview of convertible-top components
Rocker switch 1
2 Warning light
Micro-switch, latching hook (windscreen frame) 3
Micro-switch, convertible-top latch (convertible-top side) 4
Potentiometer I convertible-top interrogation 5
6 Control module
Micro-switch, convertible-top compartment lid (locked) 7
Potentiometer, convertible-top compartment lid interrogation 8
Micro-switch, left/right rear section flap up and down 9
The convertible top is actuated if:
Terminal 15 is connected via ignition.
The parking brake input is connected to ground (parking brake engaged),
No speedometer signals greater than 5 km/h (3 mph) are present.
Engine compartment lid is closed (input not at ground potential),
61 -D 7 61 01 Diagnosis/troubleshooting, convertible top
Printed in Germany -11, 1998 99661Dl
Fault memory
Overview of possible faults
1 Switch position implausible
2 Button short to ground
3 Convertible-top pot. fault
4 CTCL pot. fault
5 Timeout error
6 Calibration necessary
7 Supply voltage
8
8
61 -D 12 6101
99661Dl
Printed in GenT1any -II, 1998Convertible-top diagnosis 911 Carrera (996)
Fault, Fault code Possible causes, elimination, notes
Test point 1
Fault code 01 This fault is only stored in the memory when an operation
has taken place
(button or comfort function with the key).
1. Check response of micro-switches of rear section flaps left and right.
A defective micro-switch must be replaced.
Refer to Servo No. 61 41 19
2. Check response of micro-switch in convertible-top latch.
If the micro-switch is defective, replace the convertible-top latch.
Test point 2
Fault code 02 1. Check pin 1 to pin 4 for continuity (bitmap on "close" switch),
check button pin 2 to pin 4 for continuity
(bitmap on "open" switch).
2. Measure resistance of wires 1 and 2 to one another with
the ohmmeter. Display 1.8 -2.0 K .0.
. 6101
99661D14
61 -D 14(;onvertible-top diagnosis 911 Carrera (996)
Fault Fault code Possible causes, elimination, notes OJ 0 , -.
Test point 3
Fault code 03 This fault is only stored in the memory if the voltage at the input
of the convertible-top potentiometer exceeds or falls below
the operating range.
1. Switch ignition off and remove ignition key. With test adapter 9619,
9636 and pin template 9636, measure the resistance of
the convertible-top potentiometer at row I, pins 12, 21
and 24 with the ohmmeter. If the display 00 .Q appears,
the convertible-top potentiometer must be replaced.
Refer to Servo No. 61 66 19
2. Switch on the ignition and measure at row 1, pins 12 and 21,
with the voltmeter; nominal value (display) 0.4 -4.4 volts.
If there is no voltage display, replace the control module.
3. Calibrate the convertible top
Test point 4
CTCL pot. fault
Fault code 04 This fault is only stored in the memory if the voltage at the input
of the convertible-top compartment lid potentiometer exceeds
or falls below the operating range.
9619,9636 and pin template 9636, measure the resistance
of the convertible-top compartment lid potentiometer at row I,
pins I, 3 and 5 with the ohmmeter. If the display 00 .0. appears,
the potentiometer and drive motor must be replaced.
Refer to Servo No. 61 70 19
2. Switch on the ignition and measure at row 3, pins 1 and 3,
with the voltmeter; nominal value (display) 0.5 -4.4 volts.
61 -D 15 61 01 Diagnosis/troubleshootin~~, convertible top
Printed in Germany -11, 1998 99661D14Convertible-top diagnosis 911 Carrera (996)
8
Test point 5
Timeout error
Fault code 05 This fault is only stored in the memory if an electric motor is
actuated and does not reach the limit position within 6 seconds,
or the potentiometers of the convertible top and CTCL do not
show any change in voltage within 3 seconds.
To check the micro-switch input signals, select the input signals which
appear in the menu: Latch locked, Latch unlocked, Convertible top,
Convertible-top compartment lid side flaps, Latching hook. Actuate
the micro-switch manually (press it) to read the response in
the bitmap positions of the tester display.
192_98
If the convertible top is between "Convertible top closed" and
"Convertible top forward" and if the "Convertible top raised" input
is connected to ground (contact for micro-switch of convertible-top
latch does not lie against the top edge of the cowl panel and
does not switch), examine the tension of the convertible-top
covering using the left and right tension cables or, if necessary,
loosen by 1 or 2 turns so that the contact lies against the top
edge of the cowl panel and switches.
6101
99661D14
61 -D 16911 Carrera (996) Convertible-top diagnosis
193_98
If the convertible top is in the forward position (diagram) on closing,
check the response of the micro-switch -unlocked or not unlocked
(small diagram) -in the convertible-top latch.
194_98
If the convertible top is in the rear position (diagram) on opening,
61 -D 17 61 01 Diagnosis/troubleshooting, convertible top
Printed in Germany -II, 1998 99661D14Fault, Fault code Possible causes, elimination, notes
195_98
If the convertible top is in the centre front position (diagram) on closing,
check the response of the micro-switch -not locked or locked
8
196_98
If the convertible top is in the centre rear position (diagram) on opening,
61 -D 18 6101
99661D14
Diagnosis/troubleshooting, convertible top911 Carrera (996) Convertible-top diagnosis
197_98
If the convertible top is in the closed position (diagram) and the latching
hook has been actuated, check the response of the convertible top
(CTCl) micro-switch or adjust the Bowden cable of the central locking
hook in such a way that the micro-switch switches.
Refer to Servo No. 61 81 19
If the convertible top remains in a position not described here:
6. Switch ignition off and remove ignition key. With test adapter
of the convertible-top compartment lid potentiometer at row 3,
Refer to Servo No. 61 7019
7. Switch ignition off and remove ignition key. With test adapter
9619, 9636 and pin template 9636, measure the resistance
of the convertible-top potentiometer at row 1, pins 12, 21
61 -D 19
Printed inConvertible-top diagnosis 911 Carrera (996)
Test point 6
Fault code 06
This fault is stored in the memory after 1000 actuations or
if fault code 03, convertible-top pot. fault, or fault code 04,
CTCL pot. fault, is entered.
1. Read out and delete actuation counter 2.
2. A newly installed control module has not been calibrated.
3. Proceed as described in test points 3 or 4.
4. Calibrate the convertible top
Test point 7
Supply voltage
Fault code 07 1. Check the battery or alternator.
2. Inspect the plug connection on the control module for corrosion,
8
8
6101
99661D14
61 -D 20 Germany -11, 1998
  • Like 1
Well, I checked the hydraulic fluid reservoir. It was indeed a bit low. I added 10cc of fluid. Being an anesthesiologist, I have access to all manner of syringes and IV tubing which made it very easy to rig together a hydraulic fluid refilling apparatus.
But, alas, no change in the operation of the top. Currently has a schedule for a service visit at the dealer on Monday.
The service advisor said something about having to readjust the timing or replace cables as being the most common remedies for what sounds like my problem over the phone. We'll see. Hopefully it will be a one day in the shop fix and won't hurt the pocketbook too much.
But this is getting to be prime convertible season here in Washington, D.C. and it's gotta be done!
If anyone has any other suggestions between now and Sunday night, I'm still open to trying other fixes.
David
3 days in the shop. $1200 later. The piece that was broken was a small piece of plastic on the driver side flap that actuates a sensor to tell the top that the flaps are in place and that the top can start moving towards closing. Once that piece was changed (the whole flap was replaced, I believe) the rest of the top opening/closing orchestra could continue unimpeded. An expensive fix for a small piece of plastic. But it was 75 degrees and sunny yesterday afternoon. Makes it much easier to forget the pain of the service repair bill.
