I found 2 TSBs detailing the installation of the illuminated door sill covers. However, I need instructions on how to remove the existing plastic sill covers. Detailed instructions were referred to in the 2 TSBs as follows:
Remove inner door sill trim -> Workshop Manual 680519
Remove cover strip -> Workshop Manual 680719
Remove front side section trim -> Workshop Manual 702419
Loren and other RennTech members, any chance that you have these instructions to share?
Thanks in advance.
Edited by Andre5
They are only held on with double-stick tape.
You need a hairdryer (for heat), some dental floss (to saw away the glue) and some 3M adhesive remover (to clean the remaining glue off).
Thanks Loren. My biggest concern is the plastic trim on the driver's side door sill that houses the two switches for the front trunk and rear boot. Do you know if this plastic trim just snaps into place or is fastened down with screws?
It is my understanding the that the door sill tucks under the the rubber seal and plastic trim mentioned above. Do you know if my understanding is correct?
Regards.
