pugface
Everything posted by pugface
  1. Hi guys. Just replaced a CV axle in my 06 CTTS. Ready to button things up, but when I search for torque values, I'm finding different information from different sources. I made a little cheat sheet to take out the to garage - do these values seem right? Also, the one in pink and red are supposed to have final torque while the car is back on the ground? For the rest, can I use a jack to simulate the suspension being on the ground? (Jack it up until the upper control arm is at 90 degrees?) Thanks, any advice appreciated! pf
  2. Hi guys Did a fluid change of the transfer case of my 2006 CTTS today. All went well (I thought), but when I went to put a new drain plug in and torque to 15 ft./lb.; I never got there. The plug kept going in, went a few threads beyond flush. I was using a digital torque wrench, so I could see it got up to 11 or 12 ft./lbs., but never torqued up. The fill plug torqued up to 15 just fine. I was worrying that the plug wouldn't bottom out and I'd end up with the plug inside the case, so I stopped. Never felt anything break, or major resistance, just didn't tighten up like it was hitting something. This is a rebuilt transfer case, if it matters. 222K miles on the Cayenne. I have the old transfer case in my garage and I can see that the plug in that is standing proud a few threads. Is this normal? Any opinions on what to do?
  3. Hi guys. I have a 2006 Cayenne Turbo S, 218K miles, had it for 9 years I occasionally get the 4-wheel drive system faulty error, usually within 60 seconds of starting the car. It seems to be getting more frequent this year, and my usual 'remedies' aren't working - I even tried a new TC ECU Usual advice is to check battery of transfer case stepper motor, which I've done. I'm checking my records 2017 new battery 2019 Used Transfer case motor 2020 New transfer case motor 2022 new battery 2024 Cleaned contacts on transfer case motor 2024 new battery 2024 Another new transfer case motor 2024 Replaced transfer case ECU with used unit Where else to look? There are lots of stories about wiring harnesses under the carpet - could that be a suspect? I do live in south Texas, it is pretty hot and dry down here... Another wild guess I've been thinking about - my car has always cranked hard at startup. I've had people stop in in the parking lot and tell my my battery is dying, but it has been this way all 9 years I've owned it without trouble, so I figured its a Cayenne thing. Could a weak starter be dragging voltage down enough to trigger errors in the transfer case module? I just drove the car to town, and go the error on the way in (hadn't driven Cayenne in a week or so). Got it leaving my appointment. Stopped for a donut, on leaving there, the error went away and I drove home fine. I got the Antigravity batter tester attached, it reports cranking voltage of 10.78V when I got the error and 11.02V when it was good (if that even matters) I checked the transfer case codes with my Foxwell scanner when I got home. It says code 2039 - Transfer box potentiometer Anyone have thoughts? Thanks pf
  4. Follow up in case someone has the same issue - changing the relay didn't do anything either. I did read where some owners got this code and it turned out to be the ground wire. Mine seemed fine, but I took it off, cleaned it up, and re-snugged it. After that, I was able to run the pump in test mode. So far, CEL has not come back! Thanks for your help, Loren
  5. OK, I'm back. I would like to know why these things are closely guarded secrets to Porsche I pulled the fuse and checked it - it was fine. Cleaned it off, put it back, cleared the codes. Of course the code is back a week later, since I didn't fix anything, but I always hope... My wiring diagram shows a SAI relay in the plenum box, my parts catalog shows relays in the plenum box, but I can't find where the relay is, or exactly which is the SAI relay I found some Audi Q5 info on the plenum box (which appears to be physically identical) which shows it as position 'C', which would be Relay position 3 on the Macan. Don't know how confident I am in that, though. Does anyone happen to know either where the SAI relay is, or what its part number is? Thanks Sam
  6. Hi all ON a 2016 Macan Turbo - where is the fuse for the secondary air injection pump? I'm getting a P0411 code, pulled SAI pump and it tested good with 12V. Thinking maybe fuse is gone, but I don't see it in the owner's manual. That shows 3 fuseboxes, passenger and driver dash right inside the door, and one in the trunk It looks like there's something underneath the kick panel? Thanks Sam
  7. Thanks Loren When I got the extra ECU, I sent it and my original out to a service that clones the entire ECU - VIN and immobilizer data too, so I now have 2 identical ECUs that can be swapped. Can I ask why you suspect the ECU and not the harness? Thanks Sam
  8. Thanks for the reply! I don't think so. Honestly I'm much more familiar with non-automotive electronic control systems (my day job) than fixing cars. Is this basically re-flashing the program memory of the ECU? I don't think that has happened. Is that a dealer-only thing? Used ECU is actually very cheap, probably because they are one of the easiest things for a dismantler to remove and they don't seem to break very often. The working theory was that one of the inputs on the ECU module went bad, so I swapped with a known good one - or at least close to "known good". It did work fine for several months. Since I've swapped the ECU and the O2 sensor, I was leaning towards the wiring harness.
  9. Shoot, I meant to explain this part better: In Sep. 2022, I had the P0050 code, and my local shop replaced the sensor. The code came right back, they hypothesized that the problem was on the ECU end, said might not be worth the cost to fix. I sourced an ECU from eBay, and had my existing ECU cloned to it. When I installed the clone ECU, the CEL came right back again. This time the shop warrantied the sensor and replaced it again. On my way home from that, the CEL came on again!
  10. 2006 Cayenne Turbo S - 214,000 miles Hi all, I am trying to chase down some CELs and rough running. A little history - all O2 sensors replaced in 2016 03/2018 P2629 - shop cleaned up harness, CEL went away 12/2020 P2629 shop replaced sensor 09/2022 P0050 shop replaced sensor 10/2022 P0050 ECU swap 10/2022 Sensor replaced in case it was faulty 10/2022 CEL came on, this time I cleaned up the harness myself 12/2022 P2629 P2247 P2A03 - cleaned up harness 05/2022 P0431, P0155, P2A03 06/2022 Car went to shop for something else, they saw the problem, but on reconnecting the battery, it was OK again 06/2022 CEL came on way home from shop ☹ P2189 P0150 I cleared the codes again, drove it yesterday, it started to idle very roughly and shudder on acceleration. Drove into town again today, the CEL came back, now with a bunch of codes P1133 P2179 P2189 P0150 along with P0300 and P0307 misfires This is all looking like Bank 2 sensor 1. That is the driver’s side upstream, correct? The 6-wire plug? With the multiple sensor swaps, and the ECU swap, I would think the logical suspect is the harness. Does anyone know where the sensor wires end up on the ECU side? I’m thinking I should ring all 6 wires out on a meter and make sure the harness is OK Any other ideas? Thanks, pf
