morris124
    Panamá
    Porsche Cayenne
morris124's Achievements
  1. Hello, I changed to my uncles Porsche Cayenne V6 2004 the oil & oil filter, then the Head Valves Gasket with the SparkPlugs, and use the car after that and it was fine!, but the maintence light came in every single time, so i cheked the brakes and they were almost end, at the point that the pads sensor were worn, so I changed the brake pads with the sensor, so I turn on the car after that and the engine was fine, I moved forward to try the brakes, brake it! the put reverse, brake it again, and the cars starts to iddle between 620 rpm to 1000 rpm, and then it turned off! the I tried to start it again, and it does not start! when its suddlenly starts the engine runs in 620pms and I put the throttle and does not acelerate and then the engines turn off it self, the principal screen sends me that I have to chage 1 of the Tail lights, and when I try to start it shows me some problem with the ABS or PSM, what can you suggest? Thank You!
