Kikokiko1976
Everything posted by Kikokiko1976
  1. this happened to me when i calibrated my cayenne. drive your car around, raise and lower it, then try the calibration again. hope this helps
  2. Hi, my cayenne turbo has an error in one of the a/c flaps as per durametric. In addition to fixing it, i am planning to do a heater core bypass as well. I live in a tropical country where temeratures are always 90-95F year round with very high humidity so i will never need the heater. If any one can help me with the bypass, it would be greatly appreciated. Thanks in advance Sent from my iPhone using Tapatalk
  3. I reconnected some chafed wires at the adjustment plug but still a no go. No more faults in durametric but if i try to erase fault codes a bunch of faults will diaplay all pointing to no signal.Power and groung are ok. Can somebody provide me a wiring diagram or a pinout for the plug for the seat adjustment so i can check where signal is broken. Thank you
  4. Hi guys, my driver seat stopped working today.all the adjustments are nit working but when everyytime i removed the key it moved into an upright position. Right now its standing straight up. Used durametric this morning and error in communication and simething about bad ground. Please help.tia
  5. I just reglued mine.its held on by 2 torx screws.its fine until the next time somebody hits it while its open
  6. Hi guys, i am looking for the left front level sensor part No. of my cayenne. I read somewhere that i need to buy the old model ones as the new ones do not communicate with the older style module. This is my Vin WP1AC29P34LA91081 if anyone can help. Thank you in advance
  7. Hi, im from the philippines and new to the porsche scene.i just traded my e53 to a 955 turbo and i am doing maintenance right now. I have a brake booster error and i saw that there is a broken Vacuum T at the back of the intake and the hose runs thru the pass side valve cover. I am having a hard time dissasembling it as it is somehow attached in between crimped hoses which is attached to a solid tube that runs thru the side of the engine. Can someone tell me what line is this? I just epoxied it back as it's a PITA to remove and replace. Would want to replace it as its broken off Thank you
