ghostdog67
    france
    boxster
ghostdog67's Achievements
  1. hello does anybody knows in what material is made the rollbar ? I was betting on stainless steel, so I hoped to polish it, anybody made this ? Thanks Alain
  2. I'm looking for the part number of the 2 small speaker grill in the back ( beside roll bar ) Many thanks Alain
  3. You were right, it was the electrical connector block behind the headlight unit... the headlight bracket is now broken, and I have to buy a new one .... Thanks again Alain
  4. Hi all, I get a light problem on my Boxster 986 ( year 1998 ROW model, manual gear) Suddenly, I have no lights working on LEFT side only ( no high beam, no low beam, no side marker, no rear side marker also ) fog light works, and turn signal also Of course, I checked all bulbs and fuses Any idea or help is welcome Thanks Alain
  5. Loren : I had the same pb than bordert and followed your instructions by removing the MAF and cleaning it with electronic contact cleaner. The engine is now quite and seems have finished to 'die' on idle Pb is that I went to a PZ because I have no Durametric or other tool to read out errors codes, and the PZ tells me that the 115 error code already here is, and that I will have to replace the MAF with a new one ( 400 euros ) !!! I don't think so, but the guy told me that this could damage the lambda probe, do you think it's possible ? If I replace the MAF by myself, do you think that the DME will detect this by himself and correct his values, or should I erase the error code and "reprogram" the DME ( could a Durametric or other tool be useful for this, or are we in any way obliged to go to a PZ ? Where is situated the idle control valve ? Many thanks for your help Loren Alain from France
  6. Thanks from France, Loren Alain
  7. For Boxster S550 Spyder or Carrera Gt Commercial name of the color is GT silver or silber metal, but I need the exact color code Many thanks Alain
