Laurențiu Bercia
Everything posted by Laurențiu Bercia
  1. I just tried with another suspension ECU and problem is still here... Don't know what else to do. Maybe to try with another headlamps . But xenon ballast are new, bulbs are new, all wires are OK.
  2. Yes. They go down and up every time when I turn them on/off or when light sensor turn them on. Not only when I start the car. If I disconnect any headlight the error doesn't appear. Only errors for bulbs (I see them also in durametric), not for adjustment. I just changed xenon bulbs, error is still here... I don't know what else to try. Suspension ECU?
  3. I just changed the battery and the problem is still there. Nobody can give me an idea? What to check?
  4. Xenon with air suspension. All cables are good, connected directly into headlamps. I also have new xenon ballast Valeo Lad5g
  5. Hey. Did you fix it? I have same problem on my 2004 Cayenne Turbo. "Check headlight beam adjustment" every time when I turn on headlamps. Durametric show me no error. Everything works fine. Headlamp goes down and up but error appear instantly when I turn them on.
