joshstix
Everything posted by joshstix
  1. Transferring the pill will only make the physical key work, remote still won't work. if your car only has a physical key hole on the drivers side then be carefull relying on the physical key because the key barrel mechanism is a common failure item. And yes the two button GT key head will work fine for your 99 once it is programmed. You'll just have one button that doesn't work. Don't let the people programming it charge you for time to troubleshoot the second button ;)
