rado
Everything posted by rado
  1. "Check the oil pressure, operation of the oil pump the pressure control valve and the oil type. Check the magnetic hydraulic valve for leaks, check the sealing strips on the camshaft adjuster and camshaft adjuster itself for damage, and check the camshaft adjustment oil circuit for leaks and blockage" Those are all , I would like to check out. How do they 331kW ?
  2. You can open. Take away the black plastic caps. Down you will find camshaft adjuster. Have a look: Camshaft sensors ?
  3. What parts are those parts marked ? http://aijaa.com/Mu9Mlr
  4. What machine I can see the oil pressure ? C READER VII + SR does not display oil pressure.
  5. Where is solenoid valve ? "Solenoid hydraulic valve fault"
  6. No repair shop.... I want to know what suction the nose PA part?
  7. Sealing strips on inlet camshaft adjuster faulty - Mechanical fault in inlet camshaft adjuster - Solenoid hydraulic valve faulty How do I find ?
  8. Each is interesting but please specify each item thank you
  9. These codes, and in addition to P0421 . Where to look wrong ? Thank you allihupa. Cayenne turbo 2003
