ahereng
Everything posted by ahereng
  1. Yes, double-checked today. Fuse is ok. I checked that the lineout on headunit actually produces sound, it does. Also connected the blue/white on connects2 directly to power and connected my phone to the front-phono plugs, no sound from the amp sadly. The amp worked when I removed the old pcm-unit..
  2. I have connected the blue/white wire to the antenna/remote output on the headunit, but no sound. I also removed the "signals" plug on the amp, and verified that the power-signal actually got to the amp. Since there was a lot of wires in that plug I don't know what is for, I was wondering if some of these should be connected to anything special in order for this to work.
  3. Hi, I'm in the middle of the same process, replacing my PCM1 Hifi on my 2000 C4. I have bought the Pioneer F980Dab, and this harness https://www.connects2.co.uk/Product/ProductItem/CT20PO02 that should connect the new headunit to the original Nokia HAES 6*40w amp. But I get no sound through the amplifier and to the speakers. I have connected a separate speaker directly to the headunit just to confirm the headunit actually works, and I get sound on that speaker. Does anyone know if there are any additional trick that has to be performed to "wake up" the amp? Alexander
