lesgrossman
Everything posted by lesgrossman
  1. Dear Enthusiasts, My 2012 Cayenne V6 base model starting blowing air intermittently shortly after a regular oil change. It would blow at startup and slowly taper-off at exactly 1 minute. Then it would stay off for about 10 minutes and blow for another minute. I could not find anything on the web for my particular year/model. Please advise and thanks in advance. -bazza
  2. Dear Enthusiasts, Is there a DIY for replacing the Valve Cover for the 2012 base V6 Porsche Cayennes? I had the Check Engine Light comes on with codes: 1) P050700 - Idle Control Speed Above Setpoint 2) P218700 - Bank 1 Fuel Metering System too lean at idle speed 3) P218900 - Bank 2Fuel Metering System too lean at idle speed Also curious because the CEL showed up right after I filled up on gas. When the car is in Park, the rpms revs up and down from 1000 - 1500. Coincidentally, the fault code P261A00 - Coolant Pump 2 Open Circuit code also showed up. I wonder if they're related and if not why? I am told that this is the auxiliary water pump. However, I don't see my temperature rising. Please help. I've only had the car for 2 months and am very new to the forum. Thanks in advance. -les grossman
