Tammy88
Everything posted by Tammy88
  1. Hi, My local mechanic looked at it and told me it was the starter, but I don't always trust that he has thoroughly investigated enough to determine the problem He tends to go with the largest component and then will do a process of elimination. When I turn the key I do hear the starter click. I looked at the battery voltage and it doesn't go all the way to 12. It is on the notch below 12. Since the voltage appears to be too low, what should I check?
  2. I'm not sure if I have an auxillary battery, but I will check. When I find the auxillary battery, what should I look for? FYI - I replaced the battery under the drivers seat.
  3. Hi, I have a 2006 Porsche Cayenne S - Tiptronic and when I turn the ignition to crank it all the lights come on, the radio and anything that would normally happen happens except it won't crank. The car will go into neutral or any other gear just fine. I did notice the break pedal won't press down as far as it normally would. There are no error codes on the screen at all. I replaced the battery last year and it's been just fine. I read somewhere that I should disconnect the battery to reset the car to see if that works so I did that and it did not fix the problem. Do you have any suggestions on what I can check or what could be the problem? I'm feeling it's something simple and would like to know before I give up and take it to the dealer. Thanks for your help!
