zunamigti
Everything posted by zunamigti
  1. PS. In graph nominal power 160kw is an error from dyno personal... 150kw correct value. Enviado desde mi Redmi Note 3 mediante Tapatalk
  2. Hi! Uninstalled technotorque, cleaned maf, new bosch lambda, new aos, new fuel pump, adjusted TPS. Mods: 996 big TB, high flow headers & exhaust. Dyno result: 125,7kw at wheel (124kw at wheel are nominal value from this web http://rototest-research.eu/popup/performancegraphs.php?ChartsID=453 ) and 8Nm more of torque. Is a good graph? Enviado desde mi Redmi Note 3 mediante Tapatalk
  3. [emoji33] [emoji33] [emoji33] Really? I try it. Thanks. Enviado desde mi Redmi Note 3 mediante Tapatalk
  4. That is not spec'ed by Porsche. OK thanks. As there is a relationship between Flow and hp, I wanted to know if anyone has logged it and maximum value. regards!! Enviado desde mi Redmi Note 3 mediante Tapatalk
  5. Thanks Loren. I have this. Im asking WOT MAF Max readings. Enviado desde mi Redmi Note 3 mediante Tapatalk
  6. Anybody knows how many maf max kg/h readings for boxster? I have this readings: 553,25 at 5800rpm Enviado desde mi Redmi Note 3 mediante Tapatalk
  7. Hi. First sorry for my bad english [emoji12]. I'm doing tests to check my low performance on dyno. 187hp instead of 204hp (1997 2.5 Boxster). No cel, new lambdas, new filters (all), no dtc. I have all values correct except: -Spec. Air mass: 14-16 instead of 15.25-15.75 -Spec. air adaptation: -1 instead of 1.45-1.55 -Ignition timing: 4.5-5.3 instead of 4.8-5.8 Maf readings are correct at iddle and at 3000rpm. Peak maf readings 2nd gear WOT are about 550kg/h. Tried with another used maf and same values at wot 2nd gear. AOS? Air leak? P.S.: installed high flow headers, 996 3.4 throttle body (correct tps readings) and a plenum insert like techno torque. Plenum insert: Thanks and kind regards!! Enviado desde mi Redmi Note 3 mediante Tapatalk
