Size
Everything posted by Size
  1. This interests me, but wanted a direct user opinion-- is the increase is sound annoying when just cruising. I don't want to have to turn up the radio of give up conversation at 2-3K revs. TIA. I have this too - sound is louder at full throttle, not cruising. Not worth the money.
  2. B-K bracket only works on driver's side seat. I removed it - once you've taken off the 4 bolts, its a bit heavy but not difficult to remove. Put on a table on its back to gain access to the under part of the seat. From there, remove the electronic box mounted to a cross brace - this will give you direct access to the bolt holes to mount the bracket. Otherwise its impossible to mount.
  3. I had this identical issue in my '06 C4S. Original issue - I heard a clicking sound at low revs, valve tensioner (chain tensioner) froze. They replaced it, one month later I was back. FOund this issue, fixed it, replaced the tensioner and ever since the engine has been perfect. This sounded unusual as I may have been the only one they heard of at the time - Fall of '06.
  4. I have a C4S and like the stock Carrera S wheel. Different looking and gives a clear view of the painted caliper.
