b-tuning
Everything posted by b-tuning
  1. Hi , i took the switch from 2 cars (996tt and 997tt) without abs / psm problems , the problem is still there. If there is a way to check the pressure of an activated pre brake pump?
  2. Hi Guys, i have the same fault code 4460 on my 2002 996 turbo . I allready check the wirings by using the porsche droubleshooting > everything ok Brake sistem purged convencionally (RR,RL,FL,FR) with piwis changed ABS unit 2x new /with PIWIS purged & programmed > and changed the brakepressuresensor extra But still get the same" Fault code 4460 " brakelight switch / new and addjusted pre brake pumpe under the headunit also new and purged F.R with piwis has someone have this issue before? As soon as i accelerate above the light pops up without standing on the brake padel Thnx in advance best reguards from Germany benjamin
