Cj12
    Boulder, Colorado, United States of America
    2004 Porsche Cayenne s
  • Future cars
    911 carrera 4s
    BMW 328xi
    BMW X5
Cj12's Achievements
  1. The bank 2 is drivers side in the us and if you remove the front panel under the car you can reach up through the sway bar and the radiator and get a wrench in spark plug wrenches don’t actually work but it is 22mm wrench the part number is from Bosch is 17157 for passenger side front and 17158 for drivers side or bank 2 sensor 1 good luck it help if you remove the air box by the way when replacing the 02 sensor for bank 1 sensor 1 passenger side I have no experience with bank 2 sensor 1 but will be attempting it this weekend
  2. The easiest way is to 1) jack up car/or leave it on level ground 2) remove engine beauty cover for the drivers side 3) unscrew the screw that hold the power steering fluid container on if you remove the air filter cover you can pour all the fluid into a container 4) remove the small hose (hose on right side that connect to the metal pipe that runs behind power steering container) 5) put the end of the small hose in a container and plug the hole of the power steering container for the small hose 6) next pour new power steering fluid into the power steering container and turn car on crank steering wheel left and right and continue to add fluid 7) when new fluid is pouring out of small hose stop adding fluid and re attach the hose to the container 8) screw container back on to car then fill up sligthly above min line 9) turn wheel from lock to lock 5 or so time check level and then add as needed
  3. I have a snapped cable also and the kit was $30 on ebay I am just wondering what size the 6 rivets holding the inner door panel are the (4 large and 2 small.) on the passenger rear door
