franz229
    1997 Boxster
  • Future cars
    2006 Boxster S
franz229's Achievements
  1. Thanks for the reply. I have sit in both side, and they feel same. The only comparison I can make is with 2007 Cayman S. The Cayman seat feel much, much warmer that my boxster. I will go to the dealership and compare it with another boxster. Thanks Franz
  2. I have problem with heated seat of my 2006 Boxster. You can barely feel the heat in heated seat. It really does not matter which setting is used. The warm or the hot setting you can feel almost no heat. This problem is really noticeable with the top down. I have taken my Porsche to the dealership, and the mechanic can’t find Any error or fault in computer. My previous 1997 Boxster seat was much, much warmer. Do any one know if it is possible to increase the seat temperature. And how to do it?
  3. Thanks Loren the information. I am checking with local Porsche/Audi dealership to see it they have switch in stock. Thanks Again. Franz
  4. hi, I have a 97' boxster that must of the time it will start but sometime won't start right away. it takes anywhere from 3 to 5 min. of turning key back and forth or pulling key in and out before finally starts. Has anyone else have this Issue? 1. Car Battery checked out fine 2. Turning the key , the car makes absolutely no noise, but the dashboard light-up and self check. 3- Sometime I have lock and unlock the car with key and hear the central locking system been activated to able to start the car. any help would be greatly appreciated.....
