Bahrain
Everything posted by Bahrain
  1. when i pull the fuel pump relay the car starts for 5 seconds only nothing happened only when ever i use to brake the speedometer reaches 20km/h the engine stops but this time i braked so hard from 220km/h to 40 and the engine stops working till now no rain or flood
  2. forgot to say that when connecting direct wires from ecu to camshaft sensors a boost pressure sensor comes as a fault in diagnose and still not starting ?
  3. Thank you for your replay will try it tomorrow
  4. HI All I have Porsche 996 TT modified to 1300HP The car was running perfectly and drove more than 6000KM never had any problems except last week when i braked hard the engine stalled now the car wont start but it cranks after serveral test i found that fault in camshaft sensor Bank 1 replaced it and still doesnt start tested the DME to sensor voltage it 12V but when testing the DME out is 5V ? how come at the end of wire is 12V and beggining of it is 5V ? p0343 porsche fault code 112 - phase sensor 1 camshaft any ideas please Many thanks
  5. when I called the work I called work shop manager and he told me that we never faced this issue before and waiting from Porsche reply
  6. When I unlocked the car and opened the door , the digital km and the digital outside temperature came on but once I inserted the key turned it to position 1 the display gone ? I think there is a ghost inside the car lol
  7. I cleared the faults only 3 remaining , the gearbox fault is normal due to upgraded by MKB, Germany The last picture is the main fault
  8. Thanks for your reply yes I do have Durametric cable and software, The is modified by Protomotive and I have tuned it more to 1300 Horsepower , while I accelerate everything went dead
  9. both fuses are ok
  10. Look at the first picture , the key is out and everything is frozen
  11. The needles all are frozen even when I disconnected the battery
  12. the fuel light and engine temperature light came on all at the same time
  13. I disconnected the battery for 30 minutes still the same
  14. I will search for the parts thanks for your help
  15. HI All I'm proud to join here with pleasure if possible anyone can help please while I was driving all gauges stopped working and frozen even if I get the key out, removed - terminal for more than 30 minutes still the same called Porsche dealer and told me that we never faced this issue before lol maybe I'm the only one on this planet as you can see in the picture while driving , high bean light indicator came on , cruise control light indicator came on , Speedo frozen , rev frozen , oil and fuel frozen and lights on ? all gear lights is on ? anyone ideas please Thank you Rez
