Royal
Everything posted by Royal
  1. Great tip! To get the seat to go past 45 degrees, the trick is to: (1) With the seat in its normal position, pull the strap sharply UP such that the seat moves forward an inch or so. (If you don't do this, it will get stuck in the 45 degree position when you lift it.) (2) Once the seat has moved forward an inch or so, the seat bottom will lift to a full vertical. There's always a trick!
