Ted Tedeschi
Everything posted by Ted Tedeschi
  1. As a follow-up to my previous post, I've identified the part, its a water valve (Part#958-572-809-00). Does anyone have any tips on how to replace it. Looks like two clamps top and bottom and perhaps a vacuum line to regulate... Any guidance available on conducting the repair once the part arrives? Water Valve - Porsche (958-572-809-00) | Sunset Porsche Parts WWW.SUNSETPORSCHEPARTS.COM Porsche part # 958-572-809-00 - Water Valve
  2. 2012 Porsche Cayenne V6 Base had the Check Engine Light come on last night. Oil Pressure is showing 2 1/2 - 3 Bars on the Dash Gage, drove home plugged Schwaben Porsche Scan tool to is showing a P164D00 Oil Pressure Switch malfunction and P218700 and P218900 Bank 1 and Bank 2 Fuel Metering System, System Too Lean Lean. Is it possible that the fix for this could be as simple as a Oil Pressure Sender replacement? Suggestions for other possible causes? Appreciate the help.
  3. I have a 2012 Cayenne V6 Base, that has a slow coolant leak. It was leaking on the passenger side of the vehicle from the coolant flange (mentioned elsewhere in this forum) I replaced the flange and the o-ring and it appears to fix that leak, but I noticed it started leaking from the driver's side of the vehicle, when I looked for the leak it appears to be coming from a small square plastic box in the coolant lines on the rear drivers side of the engine... can anyone help me identify what this part is?
