John coombes
About John coombes
    Banbury, United kingdom
    Other
    Porsche Booster 986
John coombes's Achievements
  1. Hi have a P1020 code on my boxster no other codes, has been checked with main dealer scanner as well, mass airflow sensor low reading, symptoms, car will only idle for a short period then cuts out abruptly, if revs are raised it will increase revs but still try to cut out randomly, had air leaks before but threw more codes with air leaks, this fault manifested itself after hard acceleration, the only other odd thing I can find is that the non return valve next to the carbon canister under the front wing buzzes randomly, is this normal? I have checked the plug on the MAS and have a decent earth and power supply, now stumped, anyone had these symptoms before?
