Ole Andreas Thomasgaard
Everything posted by Ole Andreas Thomasgaard
  1. Is the automatic range adjustment system for yoir Ned xenon front lights working properly too ? was there wires ready and brackets front and rear for the sensor/ levelleres ? I have a 2004 halogen (none xenon) Cayenne. 3,2 the car has now a facelift 2008 turbo front end with xenon, but the range leveling system is not installled. Is it possible ? How to do ? Seems like it’s missing wires in the rear. there is brackets front and rear. And I have the levelleres, although the electric connector on the front one doesn’t fit... I have no wires from rear yet.....where red should the wires from rear be connected ? What kind of programming is neccecary ? Running dayligh doses not work work when the engine starts. light switch needs to be switched on before I start the car.......else the front light xenon does not go on. Any any help to get ?
  2. Hello i have had malfunction with ABS and 4 wheel drive have changed ABS pump. all 4 wheel senors are tested and ok. now the 4 wheel drive and and ABS works correct but the ABS indication lamp is still on. all fault codes removed. Also notice ice a slight drop in the break pedal when Iput pressure, but that’s maybe normal ? any advice ?
  3. I have changed the front of my 2004 cayenne to the facelift front. 2007... my car has not original xenon, the facelift front has xenon. I have problem that I need to turn the light switch on before I start the car, else the xenon will not turn on. Also the driving lights. Led...doesn’t work at all. Do you have any advice for me ? Email: o_a_th@hotmail.com
