Chris Owens
Everything posted by Chris Owens
  1. Thank you very much will be ordering the ceramic one today
  2. Does any know if there is a difference in the IMS bearing from pelican parts for 189 dollars and the other ones that range from 600 to 800 , seems a lot cheaper , but is it cheaper for a reason ?!
  3. Thank you for the advice and info , and other things i should keep a eye on
  4. So is the devastation something In-Should worry about , and single or double row bearings ?
  5. Ok thank you for the advice , any advice on my camshaft deviation being at 7 putting time chain pads looks like hig job dropping the engine!?
  6. I just purchased my car low miles 47k , needs IMS bearing upgrade but oil is clean and took off oil pan no metal looks good , can devaluation is at 7 , so little out of spec putting new water pump on this weekend, and advise, on that job and should I worry about my devastation and wait until I do the clutch to replace the IMS and RMS , so many different story’s on this car on line !?!? Lol
