dabistdu
About dabistdu
    Germany
    Porsche Boxster S 986
  • Future cars
    Porsche 996
dabistdu's Achievements
  1. Hi, I'm in the middle of retrofitting my Boxster S (3.2L) 986 model year 2000 with the litronic and headlight washer kit, since I got the parts out of a parts car which had both options from the factory (M601 & M288), but I'm not sure as this process will be as straight forward as it seemed at the start. First of all: I already have litronic headlights, meaning that I have the Xenon and halogen ones, not the Bi Xenon headlights, but nothing else refitted on my Boxster. The work fine, the lights work and the light output is much better than the light output of the halogen headlights. However I have to have the headlight washer option (M288) and the self leveling adjustment installed to pass German Tüv inspection. So I was wondering if any of you have information / instructions for the installation of the retrofit. As far as I know there was / is a kit offered by Porsche for refitting the Litronics, but the self leveling feature will not work, but the headlights will still move up and down to assist with the Xenon bulb the Halogen light output of the highbeams. Do you have any instructions or part numbers what I will need to install it? Is it possible to do a full factory install of the options M601 & M288 just as they would have come out of the factory? If not why is that (parts,..)? I have a second Boxster 986 (2.7L) also model year 2000, with those options equipped from the factory, but I have it currently in storage as the previous owner had an engine failure with it and I bought it with an dead engine, which I'm rebuilding too at the moment. So if you could pin point me in the right direction for the install I'd gladly appreciate it! If I get a chance I will take my second Boxster as a reference for the retrofit. I have already looked at the parts lists and at the wiring diagrams. It seems to me that I would need the two height sensors with the plastic arms etc. mounted on the wishbones (these are different too, since the have a hole in them where the arm of the headlight sensor goes through) on the left side of the car front & back, the wiring harness from the sensor to the control module, some sort of control module ( do I need one or two for both sides?) and the wiring harness from the control module to the headlights. Plus a wire connected to ground, another wire connected to Term 15 (Plus), one for the signal on high Beam and another one for the signal on light (connected at the bridge points on the relay holder) and two more wires one for Diagnosis and one for ESD. I'm confident that I can connect up all the wires, except for the Diagnosis wire and the ESD wire. What do they stand for and where do they have to be plugged in? Goes the Diagnosis wire to the obd port, where there is one pin empty? For what does ESD stand for? I have read that the control module will need to be activated. Can I do that with a durametric diagnostic tester or can the Porsche dealer enable this function? What should I watch out for when installing the headlight washer kit? Do I need a new wiper stock on the steering wheel or will my old one work just fine? I saw that in the parts list there was mentioned that the cars with option M288 (Headlight washer) have a different cap with a different symbol on the stock. Is that all the difference or is there more to it? Best regards Victor
  2. Hello, I'm new to this forum and the ownership of a Porsche. I bought a 986 Boxster S from 2000 recently and in the deal was the original PSE included in parts. The previous owner has had it installed, but never wired it up properly. Now I want to install it, but I have difficulties hooking up the electrical and pneumatic part of the system, since I want to be able to open and close the exhaust from inside the cabin. I looked up several sources and found that I would need the following parts: 99661298003 - wiring harness 99661298001 - wiring harness 99661898003 - relais 99661398710A05 - switch My question now is do I need all these parts and if so, is someone able to give me some instructions regarding the installation process of these parts? Or installation instructions for the whole PSE? Do I really need the relais? I have heard it is only there to turn off the exhaust when driving 50 to 70 km/h and it is only needed in Switzerland. The wiring harnesses are rediciously overpriced though.. I think I will make my own. Best regards Victor
