moosey
Everything posted by moosey
  1. HI Loren, when you say turn on ignition, not motor right?
  2. Just got back from the dealer after replacing fuel pump which got rid of P0174. Driving home i got another code P0507. Ive read the posts here and wanted to know could the dealer have done something to cause high idle??? My car never had this problem. 2003 996 Targa 135K.
  3. 2003 Targa with 105,000 miles . The car runs perfect, but i notice three times this week when starting and only when putting in reverse im getting like 3-4 knocking sounds from what it seems like the motor. Again the car drives fine and normal. It is only during cold starts and right when it is engaged into reverse.
  4. [quote name='logray' timestamp='1310509053' post='2047 Hey, that's what I said! :rolleyes: :D Thanks Where can i purchase it? also how will i know what size insert
  5. Does anyone have any ideas how to fix the bolt hole that keeps the igntion coil in place on a 2006 Cayenne Turbo? I noticed the gold looking bolt that keeps the ignition coil in place is stripped and the bolt holding it down will not go in anymore unless the bolt hole threads are re threaded. Does anyone know or recommend Helicoil thread repair kits?
  6. thanks moossport, so it will be the one next to the motor?
  7. got code p0134 02 sensor ahead of catalytic converter, does anyone have a picture or diagram showing the exact one that needs to be relplaced. i do know that bank 1 is on the passenger side.
  8. no problem, thanks for the effort and quick response thanks, but it already sold
  9. thanks, but it already sold
  10. Does anyone have or know someone selling a Black hardtop that will fit a 99' boxster? Need one asap
  11. Sure, here you go: 1997-1999 986 Boxster 2.5L 986-606-126-01 (all four sensors are the same.) Here is the best site I have found regarding O2 sensors for the Boxster. It is Mike Focke's site. PRESS HERE Thanks KB!
  12. Can someone post the correct part number for the oxygen sensor for bank 1 ahead of catalytic converter for a 99' Boxster.
  13. Anyone have a slight delay/jerkiness when the engine starts back up using the start stop fucntion?? I have been told by dealer that this is normal and some 2011 Cayenne's and Panamera's have more or less jerkiness before the engines fires back up after letting up on the brakes. Feedback from 2011 Cayenne owners needed.
  14. Thanks, do you know if the procedure is the same for the rear protection plate as well? Any factory instructions for this process for new skid plate.
  15. Need to replace tensioner pulley , did search could not find anything.
  16. Just confirmes the picture to the right with the plastic piece in black is the front plate for Cayenne S. So again its not for the rear!
  17. My dealer tells me that the optional front skid plate, which is the one to the left of the picture are all the same for all new 2011 cayenne. The plastic one in your picture is not for the rear
  18. Hello, I am picking up my new Cayenne S this saturday and will be ordering the front skid plate from suncoast. Has anyone here installed it. On suncoast website they state that there is drilling required. Thanks
  19. Driving yesterday and while going 15-30mph i hear this very loud metal grinding noise coming from the front wheels. It sounds like metal is being dragged on the ground or metal being scraped up against something in maybe the brakes. When driving faster the noise get louder and then I heard a loud can crashing thud also coming from the front of the car and then it all went away. I though maybe wheel bearings but ad them replaced about 30K miles ago unless they can just go bad at anytime. I dont know where to start as the sounds were pretty bad. The car drives fine at the moment.
  20. hEY pAUL, just got done installing the window regulator and it works perfect now! pretty simple. All i can say is if anyone is having a propblem with there window not lowering or rising when the door is either closed or open from the inside and can push the window down with using their hands it is the window regulator and not those microswitches.
  21. Hi Paul< i just double checked and it is pluged in.
  22. I just got done installing a window regulator on the paadenger side of my 03 C4S. Everything went perfect except for when i went to start the car he airbag light came on. I discinnected the battery before i started work on the door. Removed side air bag and set off to the side like normal. Never had an airbag light go off. Anything I can you?
  23. Paul or anyone else , when removing the window regulator is it better to do it with the window in the up or down position?
