Danny Buonsanto
Everything posted by Danny Buonsanto
  1. Hi I understand that but there was no follow up as to if it worked or not.
  2. Hello did you ever find out what was throwing all these codes? My 1999 Boxster came up with the exact same code readings and I wanted to know what you did to fix it and what it was. Hopefully you are still active on this board and will get this. Thanks!
  3. Oh thanks I plan on changing the plugs and coils anyway...how could I fix a lean mixture condition? My HC level was a bit high on the Dyno @ 15 MPH test. At 25 MPH, it was within limits...trying to pass CA smog check.
  4. Today I got these codes when scanning the check engine warning. Does anyone has had this happen like this and what you think it could be. Obviosly the chances of all 6 cylinders misfiring at once is pretty slim to none. Perhaps its bad coils and plugs that is throwing the ignition sequence off? Any thoughts or insights? My car is a 1999 Boxster base manual transmission 2.5L Thanks! P1313 Misfire, Cylinder 1, Emission Relevant P1314 Misfire, Cylinder 2, Emission Relevant P1315 Misfire, Cylinder 3, Emission Relevant P1316 Misfire, Cylinder 4, Emission Relevant P1318 Misfire, Cylinder 6, Emission Relevant P1319 Misfire, Emission Relevant
