Greenman97us
Everything posted by Greenman97us
  1. Thank you for your response. I will remove the headlight assembly and inspect I will post the results.
  2. First time poster here and great forum. I replaced the OSRAM bulb in the headlight on my 2002 996 c4 cab. It was quite easy to remove the assembly replace the bulb and reinstall. The problem I am having now is the battery is draining, Is it possible the assembly is not seated correctly, the wire on the H9 OSRAM bulb is nicked or maybe one of the one of the pins are bent on the rear connector in the assembly? Any advice would be appreciated. Thank you
