Mahee
Everything posted by Mahee
  1. Any suggestion what I should do? Should I take it to another garage? Isn’t there an overfill valve which will spit the excess atf out?
  2. I have a 986 2.5 l tiptronic which had a transmission fluid leak (just a few drops so nothing major, drove fine) so I left it to a local garage to change the gasket, filter and fluid. I had bought the ZF filter kit with gasket and 5 liters of Pentosin ATF 1. When I picked it up apparently they had filled it up with 9 liters. The additional 4 litrers if atf they used was liqui moly top tec atf 1200 which they said was the correct atf for the car. (I cant find anywhere where it says its the correct atf) Apparently it started to overflow at 9 liters, not at the usual 3,5 liters. They said it was normal since it hadn’t been used in a while. Should I be concerned? For the 9 liters? For the atf fluid they used? Or can I drive happily without worries? It drove fine the 20 km (13 miles) home from the garage.
