Todd230
Everything posted by Todd230
  1. Also added ti lugs and new oz caps to create some detail in the wheels. Subtle but I like the change. Will have to update the picture when I get the car out again.
  2. Thx! It’s a factory Aero car. Underhood sticker confirms and the rockers are white painted. They were covered with black protective film (you can see it peeling right behind front tire). I’ve since removed and used clear bra material to protect. Front lip is definitely aftermarket. I kind of like the black so haven’t looked to replace with white. @Mezgerman. Thx for the tip - I have noticed when I lock the car I don’t have the battery drain. I’ve left the radio off (rarely use) and the draw is gone So not sure if it’s a sensor issue or the radio - possibly both. Plan to dig into that when it cools off this year. Other than rocker clean up I’ve added a speed tech muffled x-pipe. Sound is amazing but not too loud. Really enjoying the car.
  3. Thank you for the info and suggestions. I will take a look at those. The rear fixed spoiler is part of the factory aero package. I did remove the radar detector and the radio is factory. I have found if I disconnect the battery long enough for the radio security to request the code my drain goes away. I’ve not measure the amps yet but I can kill the battery in hours with the radio enabled. Without entering the code I’ve yet to have a battery issue. I’ve downloaded the radio circuit schematic and plan to look at the switches in sub circuits that enable power when the ignition switch is off. The switch was replaced at Porsche once, but I suppose that can happen again so will see if I can capture current flowing at that node. The other factor in the parasitic drain is I’ve learned to lock the car. I’ve yet to try leaving it unlocked to see how bad the drain is in that condition. Again, thank you for the info and reply, Todd
  4. Hi there - moving from air cooled to a new to me 2002 white w/natural grey Interior. It’s mainly original with GT2 wheels size, offset, and tire sizes, fab speed exhaust, assuming an ECU tune of some sort (it hits .9 bar consistently), Billet diverter valves. For options it’s a tip, full carbon, full leather interior, three spoke wheel, dual electric seats, Bose sound system, and aero option. It’s got 44k miles and appears to have been well kept. I’ve had the wheels re-powder coated gloss gunmetal (from satin black), new tires (fronts were from 2006 :-)), and I’ve reconstructed the carbon dash pieces and side ac vents. Im chasing down a parasitic current draw and think I have it isolated to the radio but not 100%. Just started that process and I’m sure I will have questions. . I plan to do oil and trans fluids and probably new front disks and pads. It’s a pretty amazing performance car and I’m excited to own and work on. My last three Porsche were 86 Carrera, 70 914-6, and 67 912-6 (which paid for this one). Love the great AC and modern convenience of this car + brute strength...
