DustyM
Everything posted by DustyM
  1. Yes those are the error codes. I assuming that the buttons must send a signal to a controller or relay somewhere as the wires to those switches won't carry the sort of current needed by the seat heaters. I suspect that there is no wiring from that controller or relay to the seats If I can find out where the seat heaters get the power from i stand a chance of making it work I think.
  2. Thanks for the reply, I'll be using my car through this winter so will persevere. Currently I have installed heated seats and swapped the HVac unit for one with the seat heater buttons and enabled the function in the gateway with durametric. Unsurprisingly it doesn't work as I have no power running to the seat heaters through the yellow plug on the seats, these wires will need to be run, but from where I'm not sure yet. I did note though that if I press the seat heater buttons it generates an error code in durametric, so the ECU must be recognising that the button has been pressed although no lights come on. Vehicle Electrical System: 8035 Left Seat Heater 8036 Right Seat Heater Need to find a detailed wiring diagram. Just to add that I'm fitting these in a 2007 987 Cayman S Cheers
  3. Sorry to drag up an old post but did you ever find a solution?
