Theo1606
Everything posted by Theo1606
  1. OK, I've bought a new alarm control unit, I had the remote controls failed Transponder have worked, Boxster could be started, I have sent the keys to repair and the control unit to read the key codes. Unfortunately, the controller came back and was no longer recognized although windows, lowering when open everything works but control unit was not found in Piwis2 and a start of the Boxsters was not possible. So I had to buy a new alarm control unit, I also bought a new remote control, built-in control unit, battery connected, Piwis connected, I had learned IPAS codes to learn, learning code and immobilizer code ... this I enter, control unit connects to the DME .... I could teach the transmitter, but I get the error no signal to 86s (fuses OK) and transponders can not be taught, it comes error 2F 21 86 key not in the ignition. Signal converter at the ignition I have already exchanged It is the oldest version I16, I believe was built only one year, Piwis protocol found that on the new controller is also a newer software. Has anyone ever had an idea or problem? Best regards and thanks for Help
  2. Hello Friends , Can one somehow generate from the identification number Boxster 986 Bj. 97? Needs the code for new keys Porsche does not push them out. Or maybe someone knows someone who could get them? Thanks and best regards Theo
