pacrtg
Everything posted by pacrtg
  1. Hi, I may have sent this twice, but I could not tell if it went the first time. I have completed an upgrade to S brakes on my standard 1999 Boxster. The caliper and rotor install went great with the spacers from FVD you mentioned in your post. I have been driving for several weeks with the new red brakes and there is a substantial difference in stopping power. I have now received all the new emergency brake parts and am ready to finish the job but have a couple of questions. I assume you need to pull the rear hubs to install the new aluminum backing plates. What type of hub puller did you use? Also the stock backing plate has two parts, the outer backing plate and the inner sheetmetal plate that ears that protect the tie rod ends just inboard of the backing plates. Did you retain the inner plate or just replace both of the stock plates with the new adaptor plate? The red brakes look really good on my Pastel Yellow car, I believe all the hassle was worth the effort. Thanks in advance for your help. Regards, Rick Gorman (pacrtg)
