500
Everything posted by 500
  1. Well 70+ views and no replies, so I guess this is a pretty isolated issue.
  2. My oil pressure at idle has been jumping to 3.5+/- at F.O.T. when it's normally about 1.5...it's occuring more frequently now (9000 miles, 07 997S) and I'd imagine it's probably a faulty sending unit but I was wondering if anyone else had this issue and what the cause was/could be. Thanks in advance.
  3. I just took my rear bumper cover off this weekend and I'm not really sure this would help with an exhaust install and yes there are heatshields that cover the entire area.
  4. If the sport function is used from day one and continues to be used all the time the throttle input is not abrupt at all...it's only an issue when you drive with it off most of the time and then expect it to be a seamless transition once engaged...I even find that if I don't use it for a week the initial transition is quite touchy for the first few days until I'm used to it again. I also find it just makes the throttle response and the way the car revs (when blipping the throttle) so much better. I also turn the suspension part of sport off, as the ride is too stiff for everyday use.
  5. CARRERA S: The Carrera S is more of everything you expect from a 911: It’s more powerful. More responsive. More agile. In short, more Porsche. Instantly recognizable by its twin, dual-tube exhausts, the 911 Carrera S has a 3.8-liter flat six engine with 355 horsepower on tap at 6600 rpm and a maximum torque rating of 295 lb.-ft. at 4600 rpm. Sprinting from 0 to 60 requires just 4.6 seconds, while the top track speed is 182 mph (manual transmission model). The chassis on the Carrera S comes standard with Porsche Active Suspension Management (PASM) and rides 0.39 inches (10 mm) lower than that on the standard 911 Carrera. PASM is an active damping system which automatically adapts to changing road conditions and individual driving styles. With a choice of two damper modes— “Normal” and “Sport”—PASM offers added agility without compromising on safety and comfort. Power is transmitted to the road through a set of 19-inch wheels and tires. The added speed generated by the larger engine is harnessed by a powerful braking system developed for the 911 Turbo. The four-piston calipers have a distinctive red paint finish and come with larger cross-drilled and vented discs. Bi-Xenon headlights are standard, ensuring excellent nighttime visibility at most speeds and in most conditions. Like its 911 Carrera stablemate, the 911 Carrera S has an interior replete with driver-oriented styling cues. Features unique to the 911 Carrera S include a three spoke sports steering wheel, aluminum-colored instrument dials and Aluminum-Look dashboard trim. The letter “S” on the engine cover may be subtle, but the performance of this remarkable sports car is readily apparent from the moment you fire up the ignition with your left hand. The added capabilities offered by the 911 Carrera S enhance the athleticism and driving enjoyment without detracting from the race-bred essence that every Porsche has possessed since the very first Gmünd Coupe rolled out of an Austrian sawmill more thanfive decades ago. SPORT CHRONO: More than a collection of the world’s most refined race-bred technologies, the Porsche 911 is a driving experience. One that can now be elevated with Sport Chrono Package Plus, an optional system providing simultaneous enhancements for engine, chassis and the optional Tiptronic S transmission. Behind the wheel, you’ll experience greater levels of performance and driving pleasure. Sport mode with a touch of a button. Pressing the Sport button on the center console is all that’s required to begin exploiting the generous reserves of power and agility in a more immediate manner. In Sport mode, the engine management system’s variable parameters are recalibrated to enhance engine response. A modified throttle map empowers your right foot with a more progressive reaction to each tap of the accelerator. In higher gears, a rev-limiter works in tandem to offer additional protection for the engine under acceleration. On vehicles fitted with Tiptronic S transmission, automatic gearshifts also become faster and more dynamic.
  6. Thanks Loren. I need to replace the passenger side bumperette and was hoping I could have just removed/pulled out that side of the bumper cap to get to it.
  7. On what model and year of car? 07 997S...thanks
  8. Does the entire bumper cover need to be removed in order to replace just the passenger side bumperette? Thanks
  9. Awesome info. Thank you.
  10. Thanks I'll check it out tomorrow.
  11. I am. I'm trying to avoid the trip there if possible.
  12. I have a loose heat shield for the driver side muffler...any way I can easily repair this myself (the rattle stops if I slide my hand between the shield and lower fender) or does it require a trip to the dealer? Thanks
  13. My wife had a nail in her tire once....Once the tire people took it out she said..."I knew my brakes felt weird".... Yes i have to live the rest of my life with this girl Gotta good laugh out of that... :P
  14. Thanks I will, problem is it's intermittent from day to day and it also comes and goes within the day (service depts just love finding those kinds of problems lol). I really hope it's not anything in the valve train.
  15. Yes I realize that ... I was thinking perhaps one of the lifters may not be getting enough oil or malfunctioning in some way which may be causing the chirpping sound.
  16. Thanks. A clutch kit was recently installed along with a new flywheel all under warranty as the car was suffereing from clutch chatter since new. I believe the chirpping noise was also there before the clutch work. I will take it to the dealer if the belt test is not successful. I have read here a loose spark plug could cause the problem so I will check that too. Can it also be a lifter?
  17. Thank you RFM. If the noise is still there what might it be?
  18. That's not good LOL. Is the noise emitted from the pulley/belt intermittent? Thank you
  19. It's been my experience that dealers typically lack the incentive to find 'strange and/or intermittent' problems on warranty covered cars. What they usually do (if they can't locate or confirm the customer reported problem) is perform some other maintence action so they get reimbursed from PCNA. Good ideal to check obvious things first (if you can) before bringing the car into the dealer. Very true.
  20. Good to know, thanks. I wonder why plastic on 6 speed's and metal on tips?
  21. If I can quickly check to see if the spark plugs are torqued properly it will save me a trip, also the noise is intermittent so there's only about a 50/50 chance it will be there when at the dealership. If the plugs are tight then I'll have to bring it in for sure.
  22. Excellent...thanks :)
  23. Are the spark plugs on the 997S visable and or easily acceessable from the top of the engine so I can check them or only from under the car? Thanks
  24. Anyone know of any 997's making this noise? Thanks
  25. Thanks to Phillip I found this thread. My 07 997S is getting this intermittent chirpping sound too; my car has about 7000 miles and I've been noticing it for the last 2000 miles or so. I'd apprciate any more info anyone may have. Thanks
