geather
Everything posted by geather
  1. Not to my knowledge. Thanks for the info, Cleaned the MAF, throttle body and idle valve. No change. The car idles at the corect RPM when hot or cold and when the AC is engaged. The 'problem' only occurs for that brief few seconds after start up. The jump in RPM does not occur before the car settles down to its normal idle Any further thoughts? ge
  2. 1999 Boxster 2.5 Tiptronic. My understanding is that on start up (especially when cold) there should be a brief (1-2 seconds) period of high engine revolutions to ? quickly raise oil pressure. This then settles down to the usual cold idle at about 1200 RPM. My 1999 Boxster does not do this. It starts easily but the initial idle is rough at about 600 RPM for a second or so before it runs smoothly at 1200 RPM. The car otherwise performs flawlessly. Is this a fault or is this normal for the 1999 model year. Geoff
