Luftgekult46
Everything posted by Luftgekult46
  1. Hi Everyone I'm new to this world and thought I'd post here as I have a TT matching 2003 C4S thats suffering from a driver side front sunroof drain blockage. I posted about it over in the C4S thread, but I'm also posting here as I have the matching TT widebody on the C4S. I'm sure that some of you TT owners have had the same problem in the past, and know how to remove the plastic behind the front driver wheel well liner in order to get to the bulk head behind and therefore to the drain outlet? I can get the large bolt out up top, but its still held in tight. How else is that piece connected, and how easy is it to get that front drain cleaned - presuming it's behind there? I'd gratefully appreciate any and all help. Thanks!
  2. Hi Everyone, I'm a week into my 'new to me' 2003 C4S. Absolutely love it. I fixed a few quick things, but the biggest problem I have right now is driver side footwell has wet carpet, and I know it's my driver side A pillar drain tube thats blocked as my driver A pillar is ruined by water egress. I can only get about 25% down using weed whacker cable coming in via the sunroof hole and working down until I hit I'm guessing a block. I need to come up from the bottom, but for the life of me I can't find the drain outlet hole in the drivers front wheel well, behind the driver wheel - before the door hinge. It's driving me nuts! Talking to Loren, since I've a wide body It looks like it's in my bulkhead, ahead of the door, and behind the wheel. Here are the pics with the liner removed. Anyone know how to take off the large yellow highlighted plastic to get to the bulkhead? I removed the bolt at the top but it still held in tight. The pipe running through it is just a rubber hose that I can remove / replace. Can someone please let me know how to remove that piece, where the other fastener(s) / bolts are, or link me to a breakdown image. I feel I'm so close.. Thanks!
