Eric Valdez
    Las Vegas,NM
    2004 Porsche Cayenne Turbo
    1967 Mustang Fastback
    1993 Foxbody notch Race Car
    2021 Ford Explorer ST
  • Future cars
    2023 Ford Raptor R
    1968 Mercury Cougar
Eric Valdez's Achievements
  1. Recently I had a problem opening the rear hatch and the rear window. I manually opened the rear window and everything works but it stops working as soon as it's closed... I tested it by locking the lock mechanism with the window open and it still doesn't work. Is there anyway to test the micro switch? The reason I ask is that the window open light turns off when the window is closed, It's so confusing...
  2. Not yet, I need to get a multi meter.
  3. So I cleaned the plug on the O2 sensor and now it's giving me these codes, P0038 Above upper limit and P0141 Above upper limit...
  4. Recently I had an engine light go on so I pulled the codes to find: P0036 Heated O2 Sensor Control Circuit, Bank 1 Sensor 2 and P0141 Heater Circuit, O2 Sensor, Bank 1 Sensor 2. So obviously I ordered and replaced the O2 sensor with a direct replacement from Bosch and even after clearing the codes they still come back and so does the engine light... Anything else that could be causing this????? Thanks!
  5. Hi guys, I'm new here and need some help. I have a 2004 Cayenne Turbo and pulled the seats out to fix some electrical issues and now I don't have heated seats. I wondering if I plugged the yellow plugs in the wrong spots since the wires aren't color matched and the plugs are the same. I did remove the battery and don't know if that had anything to do with it. Thanks!
