wilder996
    996 c4s cab tiptronic
    boxster s
wilder996's Achievements
  1. I tried that but my vehicle is may 2004 and just out of warranty. To renew it they want £725 and to do a 111 point check! Therefore i would have to pay for it regardless! :(
  2. I took the drivers seat out of my C4S cab (with memory) for a refurb. After refitting it went back electrically and now just clicks the relay and nothing else which ever way you press the buttons. It has the big control box under the front of the seat and the connectors for the motors seem to go in anyway you like which seems odd. I have powered the motors manually and they work. I have also checked with a voltmeter and it appears to be switching in the control box,relay clicks but no movement!! Any ideas?? Seems like the box but i cannot understand why it has just gone, seems coincidental after the seat being in bits!!
  3. :help: Hi, i bought a 2004 996 C4S cab with PCM2 and it has no sound. The display states "system error: phone, amplifier not available" any ideas anyone???? Everything is plugged in correctly as far as i can see, Baffled!!! The display/radio/cd etc all seen to work fine. There is only the top and bottom connectors plugged into the back of the unit and i cannot find a middle one in the loom anyway, so i presume it has no internal amp- is that correct?? Any help or similar faults would be greatly appreciated.
