floflo82
floflo82's Achievements
  1. This thread is a godsend! I have an issue with the steering lock in my cayenne not enganging properly. The ELV is doing its job just fine, but the locking mechanism inside the column itself seems to be broken: I've removed the ELV and then manually put the locking tab on the column into the lock position, still the same. So I'll get a replacement column, swap over the ELV and control modules. I was just worried that I had to remove half the exhaust in order to get the **** column out. But apparently that is not an issue when the steering shaft seperates easily. Thanks!
