stcan
Everything posted by stcan
  1. looks like there is a short in the board. There is constant power on the brake trigger input in the box. I am wondering if that can also be software issue. Is there a way to do factory reset on the rear module firmware? Steve
  2. Thanks for your help Loren, it's the control unit. I replaced it and problem is fixed.
  3. can you explain the arrow to the line in the brake pedal switch. What does that mean. Can you explain this schematic on how it works?
  4. It's the stop light that's staying on all the time. I change the stop light switch by the brake pedal, that didn't fix it.
  5. Thanks Loren, I will check the fog light and the headlight switch. Can you explain how the stop light circuit work?
  6. Hi, I am having trouble with my brake tail stop light staying on all the time. Looking at the schematic, looks like the fuse C F4 is feeding the CU PSM and it's re-feeding the A6 Stop light switch. Is my PSM box broken? Can I put a diode so that it doesn't back feed the power Thanks
